Introduction To BPF & eBPF
For DevOps and Site Reliability Engineers (SREs), understanding and applying the right tools for monitoring and troubleshooting is crucial. Among the various technologies available, BPF (Berkeley Packet Filter) and its extended version, eBPF (extended Berkeley Packet Filter), have emerged as powerful tools. But what exactly are BPF and eBPF, and how do they differ? This article will delve into the basics of both, highlight their differences, and explore their applications in modern DevOps and SRE practices, with a special focus on observability.
Berkeley Packet Filters (BPF) Explained
BPF, or Berkeley Packet Filter, is a technology that allows programs to filter and capture network packets efficiently. Developed in the early 1990s, BPF provides a way to write programs that can perform packet filtering directly in the kernel, making packet capture faster and more efficient than user-space alternatives.
Key Features of BPF
Packet Filtering
BPF programs can filter network packets based on various criteria, such as IP addresses, ports, and protocols.
Kernel Space Execution
BPF programs run in the kernel space, which allows them to process packets with minimal overhead.
Efficiency
BPF’s design minimizes the performance impact on the system, making it suitable for high-throughput network applications.
Common Use Cases For BPF
Network Monitoring
Tools like tcpdump and Wireshark use BPF to capture and analyze network traffic.
Security Applications
Intrusion detection systems can use BPF to filter and inspect network packets for malicious activity.
Introducing eBPF
eBPF, or extended Berkeley Packet Filter, builds on the original BPF framework and significantly expands its capabilities. Introduced in the Linux kernel, eBPF allows for more complex and versatile programs that can interact with various kernel subsystems beyond just network packets.
Key Features of eBPF
- Extended Functionality: eBPF extends BPF’s capabilities to include tracing, profiling, and performance monitoring.
- Safety and Verification: eBPF programs are verified before execution to ensure they do not harm the system, providing a safe environment for kernel-space execution.
- User and Kernel Space Interaction: eBPF enables interaction between user-space applications and the kernel, allowing for advanced monitoring and debugging.
Common Use Cases For eBPF
- System Monitoring: eBPF can be used to collect detailed performance metrics and trace system calls, providing insights into system behavior.
- Security Enforcement: Tools like Cilium use eBPF for implementing security policies and micro-segmentation in cloud-native environments.
- Performance Profiling: eBPF allows for detailed profiling of applications, helping identify performance bottlenecks.
Observability With BPF & eBPF
Observability is a key aspect of modern infrastructure management, enabling DevOps and SREs to gain deep insights into system performance and behavior. Both BPF and eBPF play crucial roles in enhancing observability.
Enhancing Observability with BPF
- Network Traffic Analysis: By capturing and analyzing network packets, BPF provides visibility into network traffic patterns and potential bottlenecks.
- Troubleshooting Network Issues: BPF helps in identifying and diagnosing network-related issues by filtering and inspecting packets.
Enhancing Observability with eBPF
eBPF takes observability to the next level by providing more comprehensive and detailed monitoring capabilities:
- System Call Tracing: eBPF can trace system calls, giving insights into how applications interact with the kernel and identifying potential issues.
- Performance Monitoring: eBPF can collect detailed performance metrics, such as CPU usage, memory allocation, and I/O operations, allowing for granular monitoring of system performance.
- Dynamic Instrumentation: eBPF allows for dynamic instrumentation of running systems without the need to modify application code or restart services, making it ideal for real-time monitoring and troubleshooting.
Practical Applications of eBPF For Observability
Application Performance Monitoring By using eBPF, DevOps and SREs can monitor application performance in real-time. For example:
#include <linux/bpf.h>
#include <bpf/bpf_helpers.h>
// eBPF program to monitor CPU usage by process
SEC("tracepoint/sched/sched_switch")
int on_cpu_switch(struct trace_event_raw_sched_switch *ctx) {
u32 pid = bpf_get_current_pid_tgid() >> 32;
u64 ts = bpf_ktime_get_ns();
// Log the timestamp and PID of the process switching to CPU
bpf_printk("PID %u switched to CPU at %llu ns\n", pid, ts);
return 0;
char LICENSE[] SEC("license") = "GPL";
This eBPF program traces CPU context switches and logs the PID and timestamp of processes switching to the CPU, providing valuable data for performance analysis.
Can eBPF Replace BPF?
eBPF is backward-compatible with traditional BPF, meaning it can handle all the tasks BPF was originally designed for, including:
- Packet Filtering: eBPF can still be used to filter network packets as BPF does, making it a seamless upgrade for tools like tcpdump.
- Raw Socket Processing: Applications using BPF for direct socket access can also use eBPF without modification.
However, eBPF extends these capabilities significantly, allowing for a much broader range of use cases that traditional BPF couldn’t support, such as:
- Dynamic Event Attachment: eBPF can attach programs to various kernel hooks (e.g., system calls, kprobes, tracepoints, and more).
- Programmable Logic: eBPF allows for more complex logic in programs compared to BPF, which was limited in computational power.
- Enhanced Observability: Tools like bpftrace use eBPF to extract rich telemetry from the kernel, going far beyond basic packet inspection.
Why eBPF Is Always A Better Choice
Backward Compatibility
It seamlessly supports traditional BPF programs while enabling modern enhancements.
Ecosystem Growth
The growing ecosystem around eBPF provides more tools, libraries, and frameworks, making it the de-facto standard for new developments in observability and networking.
Network Latency Monitoring
eBPF can also be used to monitor network latency by tracing network events:
// eBPF program to trace network packets and calculate latency
SEC("tracepoint/net/netif_receive_skb")
int on_packet_receive(struct trace_event_raw_netif_receive_skb *ctx) {
u64 *start_ts;
// Retrieve the start timestamp from packet metadata
start_ts = bpf_get_socket_cookie(ctx->skb);
if (start_ts) {
u64 latency = ts - *start_ts;
bpf_printk("Packet latency: %llu ns\n", latency);
return 0;
This eBPF program calculates the latency of received network packets, helping identify network performance issues.
BPF vs. eBPF: Key Differences
While BPF and eBPF share a common heritage, they differ significantly in their capabilities and applications. Here are the key differences:
Scope & Capabilities
BPF: Primarily focused on network packet filtering. eBPF: Extends beyond packet filtering to include tracing, profiling, and other system-level monitoring tasks.
Flexibility & Complexity
BPF: Limited in scope but simpler to implement for network filtering tasks. eBPF: More complex and powerful, suitable for a wide range of monitoring and performance tasks.
Safety & Security
BPF: Basic safety mechanisms, mainly focused on preventing packet filter crashes. eBPF: Advanced safety features, including program verification to prevent harmful actions in the kernel.
Use Cases & Applications
BPF: Best suited for network monitoring and basic filtering tasks. eBPF: Ideal for comprehensive system monitoring, security enforcement, and performance profiling.
Real-World Applications of BPF & eBPF
To illustrate the practical differences between BPF and eBPF, let’s look at a couple of examples.
Example 1: Network Packet Filtering with BPF
// Simple BPF program to filter TCP packets on port 80
struct bpf_program {
struct bpf_insn insns[10];
int len;
// BPF instructions to filter TCP packets on port 80
struct bpf_program my_program = {
.insns = {
{ BPF_LD + BPF_H + BPF_ABS, 0, 0, 12 }, // Load the Ethernet type
{ BPF_JMP + BPF_JEQ + BPF_K, 0, 5, 0x0800 }, // If IP, jump to IP header
{ BPF_LD + BPF_B + BPF_ABS, 0, 0, 23 }, // Load the IP protocol
{ BPF_JMP + BPF_JEQ + BPF_K, 0, 3, 6 }, // If TCP, jump to TCP header
{ BPF_LD + BPF_H + BPF_ABS, 0, 0, 20 }, // Load the TCP destination port
{ BPF_JMP + BPF_JEQ + BPF_K, 0, 1, 80 }, // If port 80, accept packet
{ BPF_RET + BPF_K, 0, 0, 0xFFFFFFFF }, // Accept packet
{ BPF_RET + BPF_K, 0, 0, 0x00000000 }, // Reject packet
.len = 8
Example 2: System Call Tracing with eBPF
// eBPF program to trace open system calls
SEC("tracepoint/syscalls/sys_enter_open")
int trace_open(struct trace_event_raw_sys_enter* ctx) {
char filename[256];
bpf_probe_read_user_str(filename, sizeof(filename), (char*)ctx->args[0]);
bpf_printk("Opening file: %s\n", filename);
return 0;
Applying BPF & eBPF In DevOps & SRE
Understanding how to apply BPF and eBPF can significantly enhance monitoring, debugging, and security practices in DevOps and SRE environments. Here are some practical tips:
Monitoring & Observability
Network Performance: Use BPF for lightweight packet filtering and monitoring network performance. System Performance: Leverage eBPF for detailed system performance metrics, including CPU, memory, and I/O usage.
Security
Intrusion Detection: Implement BPF-based filters to detect and log suspicious network activity. Security Policies: Use eBPF to enforce security policies at the kernel level, providing robust protection against various threats.
Debugging & Profiling
Application Profiling: Employ eBPF tools like BPF Compiler Collection (BCC) to profile applications and identify performance bottlenecks. System Tracing: Use eBPF for tracing system calls and understanding system behavior during complex operations.
Further Resources
For those interested in diving deeper into BPF and eBPF, here are some valuable resources:
Books: “Linux Observability with BPF” by David Calavera and Lorenzo Fontana, “BPF Performance Tools” by Brendan Gregg Websites and Tutorials: eBPF.io, BCC Documentation
By understanding and leveraging BPF and eBPF, DevOps and SREs can gain deep insights into their systems, improve performance monitoring, and enhance security measures. These powerful tools are essential for modern infrastructure management, providing unparalleled visibility and control.
The Limitations of eBPF: Challenges & How To Overcome Them
Despite its power, eBPF has some limitations that users should be aware of:
Kernel Version Dependency
eBPF is supported only on Linux kernels version 4.4 and later, and newer features of eBPF require even more recent kernel versions (e.g., 5.x).
This dependency can limit its use on older systems or those running non-upgradable kernels.
Steep Learning Curve
Writing eBPF programs involves low-level programming in C, making it challenging for beginners or those unfamiliar with kernel programming.
Debugging eBPF programs can also be difficult due to the constraints of running in a kernel context.
Kernel Verifier Rules
eBPF programs must pass the kernel’s verifier, which enforces strict rules for safety:
- Programs must terminate (no infinite loops).
- Programs must not use uninitialized memory.
- Programs cannot directly call kernel functions unless explicitly allowed.
These restrictions ensure safety but can make program development complex and debugging tedious.
Limited Cross-Platform Support
While eBPF is native to Linux, there are ongoing efforts to port its functionality to other platforms like Windows and FreeBSD, but support is still in early stages and lacks full parity.
Execution Environment Constraints
eBPF programs execute in a sandbox and cannot perform blocking operations (e.g., sleep or I/O). This limitation requires designing programs specifically for the eBPF environment.
Resource Usage
While eBPF incurs minimal overhead, running complex or multiple eBPF programs simultaneously can consume CPU cycles, especially for high-frequency events.
Maintenance & Expertise
The tooling and libraries around eBPF are evolving rapidly, requiring ongoing maintenance of eBPF-based solutions to keep up with updates and kernel changes.
Expertise in eBPF is still niche, which can make hiring or collaboration difficult for teams adopting it.
Overcoming Limitations of eBPF
- Use higher-level frameworks like bcc or bpftrace to simplify development and debugging.
- Stay updated with kernel versions to unlock newer features.
- Adopt existing tools like Cilium, Falco, or bpftrace, which abstract much of the complexity for common use cases.
Detailed Terminology For BPF & eBPF
What is BPF?
Berkeley Packet Filter (BPF), initially introduced in the early 1990s, stands as a landmark technology in the domain of network traffic filtering. At its core, BPF was designed to provide a highly efficient means of packet filtering, surpassing traditional methods that required packets to traverse from kernel space to user space for processing. This innovative approach allowed for direct packet analysis and decision-making within the kernel, thereby significantly reducing latency and improving overall system throughput. BPF operates on a simple yet powerful premise: it utilizes a virtual machine (VM) within the kernel to run programs that decide the fate of packets (e.g., to accept, reject, or forward them). This mechanism not only streamlines packet processing but also introduces a level of programmability and flexibility previously unseen in kernel-level operations.
What is eBPF?
Extended Berkeley Packet Filter (eBPF) emerges as an evolutionary leap from its predecessor, transforming the landscape of kernel optimization and programmability. eBPF extends the capabilities of the classic BPF, introducing a more powerful in-kernel virtual machine capable of executing small programs written in a restricted C-like language. These programs are compiled into eBPF bytecode, which the eBPF VM can then execute with high efficiency. eBPF’s innovation lies in its versatility and the breadth of its application domains. Beyond network packet filtering, eBPF enables performance monitoring, security policy enforcement, and even dynamic tracing of kernel and user-space applications. This expanded functionality is facilitated by eBPF’s advanced features, such as an extended set of instructions, larger and more complex data structures, and the ability to call a set of pre-defined kernel functions, known as “helpers.”
