Databases
What Is Cardinality In Databases: A Comprehensive Guide
Why Cardinality Is Key To Database Performance
by Netdata Team · January 29, 2024
An Introduction To Cardinality
Cardinality is a fundamental concept in databases that plays a crucial role in designing efficient databases and optimizing query performance. For those new to databases, understanding what is cardinality is essential for effective data management. This comprehensive guide will explain the meaning of cardinality, its types, and its impact on database performance, making it accessible for both beginners and intermediate users.
What Is Cardinality In Databases?
Cardinality in databases refers to the uniqueness of data values contained in a column. It essentially measures how many distinct values exist in a column compared to the total number of rows in a table.
Cardinality can be understood in two main ways:
  • Mathematical Sense: The number of elements in a set.
  • Database Context: The number of unique values in a column, which helps in optimizing how data is stored and retrieved.
The Importance Of Cardinality In Databases
Understanding cardinality is vital for database performance and efficiency. It affects query optimization, indexing, and overall database design.
How Cardinality Impacts Query Optimization
Database query optimizers use cardinality to determine the most efficient way to execute queries. Knowing how many unique values are in a column helps the optimizer choose the best method to retrieve data.
For example, in an e-commerce database, the ProductID column typically has high cardinality because each product has a unique ID. This makes it ideal for indexing. On the other hand, the Category column might have low or medium cardinality because many products share the same category.
The Role Of Cardinality In Indexing
  • High Cardinality: Columns with high cardinality are great for indexing because they allow the database to quickly locate specific rows.
  • Low Cardinality: Columns with low cardinality are less effective for indexing as they result in larger sets of data to be scanned.
Real-World Use Cases Of Cardinality In Databases
Cardinality has a direct impact on how well a database performs in different real-world scenarios. Here are a few examples of how it plays a role across various industries:
E-commerce
In a product database, the ProductID column usually has high cardinality, as each item is unique. Indexing this column ensures fast lookup and smooth checkout experiences. Conversely, the Category or Brand columns tend to have lower cardinality and are less useful for indexing.
Finance
Transaction logs often include high-cardinality fields such as TransactionID or Timestamp, which are essential for fraud detection and audit trails. Mismanaging these columns can lead to bloated indexes and slow queries.
Healthcare
In patient records, fields like PatientID and VisitDate have high cardinality. Efficient indexing of these columns is crucial for retrieving patient histories quickly, especially in emergency scenarios.
SaaS Analytics
Multi-tenant platforms often track user behavior across applications. Fields like SessionID or UserID can have extremely high cardinality. Monitoring and managing these effectively is key to maintaining performance.
By understanding how cardinality affects common workloads, teams can make better decisions when designing schemas, building indexes, or writing queries.
High Cardinality vs Low Cardinality: What’s The Difference?
High Cardinality
High cardinality refers to columns with many unique values. These columns are typically used for primary keys or unique identifiers. Example: In a user database, the Email column would have high cardinality because each user has a unique email address. This uniqueness makes it suitable for indexing, allowing for fast searches and data retrieval.
Low Cardinality
Low cardinality refers to columns with few unique values. These columns are often used for categorical data. Example: In a survey database, the Gender column would have low cardinality with values like “Male” and “Female”. Since there are only a few distinct values, indexing this column might not significantly speed up queries.
Cardinality In SQL Databases
In SQL databases, cardinality affects query execution plans. When you execute a query, the database engine uses cardinality estimates to determine the most efficient way to retrieve data.
How Cardinality Affects Query Performance
  • Execution Plans: The query optimizer creates execution plans based on cardinality to minimize resource usage.
  • Statistics: Databases maintain statistics about cardinality, often stored as histograms, to help the optimizer make accurate decisions.
Example Of SQL Cardinality
Consider the following SQL query:
SELECT * FROM employees WHERE department_id = 5;
If the department_id column has low cardinality (few departments), the optimizer might choose a full table scan. However, if it has high cardinality (many departments), it might use an index to quickly find the matching rows.
Cardinality vs Selectivity: Key Differences
Cardinality
As mentioned above, cardinality refers to the number of distinct or unique values present in a database column. High cardinality indicates many unique values, while low cardinality means there are fewer distinct values with many repetitions.
For example:
In a “Customer ID” column, each customer might have a unique ID, leading to high cardinality. In a “Country” column for an international company, there may be fewer distinct values (e.g., USA, UK, India), resulting in low cardinality. Cardinality helps databases decide how to process queries by giving an understanding of the data distribution within a column.
Selectivity
Selectivity, on the other hand, refers to the fraction of rows that a database query will return based on a condition applied to a column. It is a ratio between the number of matching rows and the total number of rows in the table.
Selectivity is expressed as a value between 0 and 1, where:
  • A selectivity of 1 means all rows match the query (low selectivity).
  • A selectivity of 0 means no rows match the query.
  • A selectivity close to 0 means the query returns a very small fraction of rows (high selectivity).
For example:
If a “Customer ID” column has a query condition like WHERE CustomerID = 123, only one row will likely match because the column is highly unique, resulting in high selectivity. If a query is applied to a “Gender” column with a condition WHERE Gender = ‘Female’, and half the database consists of females, this would result in low selectivity (because many rows match the condition).
How Cardinality And Selectivity Work Together
While cardinality measures the uniqueness of values in a column, selectivity measures how “exclusive” a query condition is in returning rows. Higher selectivity generally leads to more efficient queries, as fewer rows are returned, whereas lower selectivity can indicate a broader query that returns many rows.
Both concepts are important for database query optimization:
  • High cardinality columns (with many unique values) typically offer high selectivity when queried, making them good candidates for indexing.
  • Low cardinality columns (with many repeated values) often have low selectivity, which can make indexes less effective for query performance.
Monitoring & Managing Cardinality
Effectively managing cardinality involves using database management tools to monitor and analyze data distribution.
Database Management Tools & Techniques
  • Monitoring Tools: Tools like Netdata Database Performance Monitor can help track and understand cardinality in your database.
  • Statistics Updates: Regularly update statistics to ensure the optimizer has accurate information for query planning.
Cardinality Challenges In Time-Series Monitoring Systems
In time-series databases used for observability and monitoring, such as Prometheus or InfluxDB, cardinality can become a major challenge.
High-cardinality metrics, typically caused by excessive or overly granular labels, can lead to:
Increased Storage Usage
Every unique combination of labels creates a new time series, multiplying the amount of data stored.
Slower Queries
As the number of series grows, queries take longer to execute, especially when scanning across many time series.
Label Explosion
This happens when dynamic values like user IDs, hostnames, or timestamps are used as metric labels, resulting in millions of unique series.
For example, a metric like http_requests_total{user_id=““123"”} repeated for every user can generate enormous cardinality, putting strain on the system.
Best Practice: Use labels thoughtfully. Avoid dynamic values as label keys, and periodically audit your metrics to control label cardinality.
Monitoring tools like Netdata offer real-time visibility into cardinality trends, helping you detect and fix high-cardinality issues before they affect performance.
3 Best Practices For Working With Cardinality
1. Regular Monitoring
Keep an eye on how cardinality changes over time.
2. Optimize Indexes
Adjust indexes based on cardinality to improve performance.
3. Update Statistics
Ensure database statistics are up-to-date for accurate query optimization.
Common Pitfalls When Managing Cardinality
While understanding cardinality is important, applying it incorrectly can lead to inefficiencies and performance bottlenecks. Here are some common mistakes to avoid:
Over-Indexing Low-Cardinality Columns
Creating indexes on columns with very few unique values (e.g., Gender, Country) may increase storage usage without improving query performance.
Underestimating High-Cardinality Dimensions In Analytics
In business intelligence systems, visualizing high-cardinality fields (like CustomerEmail) can overwhelm dashboards and slow down queries.
Ignoring Data Growth
A column might start with low cardinality but grow over time. Failing to monitor these changes can cause outdated statistics and suboptimal query plans.
Label Explosion In Observability Tools
Tagging metrics with too many high-cardinality labels in monitoring platforms can lead to excessive memory usage and degraded performance.
Avoiding these anti-patterns can help ensure your database and observability stack remain performant and scalable over time.
Final Thoughts On Cardinality In Databases
Understanding what is cardinality in databases is crucial for designing efficient databases and optimizing query performance. By knowing the types of cardinality and their impact on database operations, you can make informed decisions about indexing, query optimization, and overall data management.
For further insights and tools, explore additional resources on database performance and optimization to enhance your database management skills. By mastering the concept of cardinality, you’ll be better equipped to manage and optimize your databases effectively
Cardinality In Databases - Frequently Asked Questions (FAQs)
What Is Considered High Cardinality?
High cardinality refers to columns or metrics that have a large number of unique values, such as Email, TransactionID, or UserID.
Is High Cardinality Good Or Bad?
It depends. High cardinality is useful for indexing and precise querying but can increase memory usage and slow performance if not managed correctly.
How Can I Find Cardinality Issues In My Database?
Use your database’s query planner, histograms, or monitoring tools like Netdata to inspect data distribution and identify high or low cardinality columns.
How Do PostgreSQL, MySQL, Or Oracle Handle Cardinality?
These databases maintain statistics on column cardinality to help their query optimizers choose the most efficient execution plans.
Does High Cardinality Affect Dashboards Or Analytics?
Yes. High-cardinality dimensions in BI tools can slow down dashboards and overwhelm filters or aggregations.
